Is there any way to define point object rotation as a User Defined Property AND be able to use that property to set drawing point rotation upon import of a point file?
Thank you.
Thanks Steve. Instead of applying a global rotation by dkey, I'd like to be able to export a population of drawing points with their manually-set object rotations intact. User defined properties is the only tool I can think of that might do this. Maybe there's another way.
So, is it possible to preserve object rotation, and have C3D recognize and apply that property upon import of a point file containing this info?
Again, thanks.
It is possible to do that programmatically, via the API. I don't know of any other way.
Thanks Sinc. Out of my league.
I was trying to come up with other solutions for the battle to provide data to a client running an earlier version of the program. Back to the drawing board. This is just bad.
