Civil 3D Forum
Point Markers Not Printing
5 REPLIES 5
mconway
2984 Views, 5 Replies
I have COGO Point Marker Styles that have a custom marker set to "View" Orientation. When I am in Plan View, they print fine. When I orbit to Front or Side View, I can see that they are "Rotating so that I can see them, but, they will not print.
Any Ideas?
At your service,
Mark A. Conway
Director - Applied Technology
Autodesk Certified Instructor
AutoCAD & Civil 3D 2014 Certified Professional
Infrastructure Design Suite BIM Specialist
Follow me on Twitter @CADventurer
5 REPLIES 5
andrewpuller3811
in reply to: mconway
I would look into the block you are using for the marker.
Check if the blocks components are on a non-plotting layer.
Also check the layers in the point style to see if they are set to non-plotting layers.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
mconway
in reply to: andrewpuller3811
Andrew,
  Sorry for the delay. I was teaching a class last week and had no opportinity to reply.
Neither of your great suggestions are the issue. I am using a Civil 3D Custom Marker (not a block). Maybe I can look into changing that. I also checked all of the layer settings thay are all set to Plot.
  I thinks this maybe something to do with scaling. I have now noticed that the markers are plotting but very small.
At your service,
Mark A. Conway
AllenJessup
Check your Point Marker Style and make sure the marker is visible in Model as well as Plan.
Allen
Allen Jessup
CAD Manager - Designer
mconway
in reply to: AllenJessup
All of those settings were correct. There seems to be an issue with Custom Markers Printing in Model Views. I have tried various settings in 2014 and 2015. In the end I created a Multi-view Block and assigned it to the marker. Works great!
At your service,
Mark A. Conway
mconway
Also, Model views will not plot with a 2D AutoCAD Block Symbol Set to View Orientation in Marker Style. Maybe something for Autodesk to look at.
At your service,
Mark A. Conway
Rail Community
