Oh, and just to be explicit, the default settings for the "_All Points" point group are "Standard" for the Point Marker, and "<None>" for the Point Label. Unless you change these values, all newly-created points will appear as a Point Marker with no label (at least until you add the points to a Point Group, or unless you assign a style directly to the point).
Best bet is to change the settings on the "_All Points" point group in your template, so that they are the way you want them for all new drawings. Then you'll see a marker and label for all new points you create.
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
