I have a question regarding point label styles and dragged state settings. When dragging point labels to a more legible location the color of the point number, elevation and description revert to a ‘bylayer’ setting. I don’t want this, I want them to keep the colors they have pre-dragged state. We control our pen weights by color. For example: the point number is usually the darkest and the elevation and description are much lighter, they are not all one color which is what we are forced to have when dragging point labels.
It just seems like very strange behavior, why allow us to change the color of the individual components of an un-dragged point label but not a dragged point label style.
Is there a way around this?
Solved by Jeff_M. Go to Solution.
Change the dragging state setting in the point label style to the color of choice. It is problably set to bylayer.
Thanks, but you didn't understand my question and situation. We don't want or need the point number, elevation and description to be all one color , we want the ability to have individual colors just like they exist pre dragged state.
Sorry about that. Is your dragged state set to as composed or stacked. As composed keeps all setting as pre dragged state.
When I set it to composed my justification and leaders lines get all messed up. But yes it does keep the colors the same, just not in a legible state.
Perhaps this will help. It also works for point labels in a dragged state.
http://civil3dplus.wordpress.com/2010/01/20/dragged-state-point-label/
Brian, I have found that workaround but I want more than a work around for a function that used to work just fine in LDD. I don't want to have to rotate each and every point 180 degrees, that seems...well cumbersome and inefficient but since that's what Autodesk gave us I guess that's what I'm forced to do.
I like 3d in general it's just these little things that really really annoy me and often ask myself 'who thought of this and why did they set it up this way when it worked perfectly fine before?
They really need some beta testers in real world scenarios.
Did you try my solution? Many of the Beta testers ARE real world users. Perhaps you'd like to sign up and give your input on the next version(s)? https://beta.autodesk.com/signup/
Sorry Brian, somehow I missed your post. You have the solution,much thanks.
Powerful software, but the setup can be brutal to figure out.
One last question, hopefully an easy answer. How can I keep my point number, elevations and descriptions from being flipped when in a dragged state. Undragged state = #, Elev, Descr. Dragged state = Descr, Elev, #. Probably an obscure toggle somewhere?
No toggle, you just need to create your components in the layout tab in the order you want displayed if you drag it out.
-Bruce
Thanks much, that fixed it!
Wow, yet another unknown and not obvious by any stretch of the imagination setting/function. We've been using the out of the box style and just modifying it to meet our needs. We'll definitly be fixing that soon.
The OOTB styles are pretty good for the most part but some of them just suck. I wonder if they were included with the software with the intent to be used in production or just as an example of some styles.
