AutoCAD Civil 3D General Discussion
Member
DSpillman
Message 1 of 4 (121 Views)
Point Label Leader Head Skewed
121 Views, 3 Replies
02-25-2014 01:34 PM
I am working in Civil 3D 2011 and I have created a point label style (with user defined properties, but I don't think that is the issue) for some test holes for SUE to label pipe size, type of utility, measure down, etc.  When I drag my leader (in non rotated model space) the leaders apperance going from the label to the marker looks normal.  However, as soon as I rotate my model space view the leader appears skewed, as if it is being drawn from a 0 elevation to the point elevation.  At this time having the skewed leader is not an issue, but it could be for further projects.  Resetting my dview back to 0 makes the apperance of the leader head normal again.
Valued Mentor
awood
Message 2 of 4 (115 Views)
Re: Point Label Leader Head Skewed
02-25-2014 01:53 PM in reply to: DSpillman
Does setting the Label Style => General tab => Orientation Reference to View help?
HTH
AWood
Member
DSpillman
Message 3 of 4 (79 Views)
02-26-2014 11:22 AM in reply to: awood
It does not.  I have tried combinations of all different types of settings for behavior for the Point Label Style and for the Point Style.
Active Contributor
wetsnow13
Message 4 of 4 (61 Views)
02-28-2014 10:54 AM in reply to: DSpillman
When you are changing your view angle are you rotating in 3D?  I'm not sure if you can label in 3D, aka not a 2D plan view
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
