AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 5 (186 Views)
Point File Formats list order
186 Views, 4 Replies
10-01-2012 01:01 PM
Does anyone know how the order of the list of Point File Formats is controlled?
We have a large list of formats predefined for doing coordinate transformations between various coordinate systems, but there does not seem to be any logical order to the list of formats.
Can I change the order of the list?
Regards
Caleb Baildon
Surveyor
Opus International Consultants Ltd
Greymouth, New Zealand
Civil3D 2014 - Windows7 64bit
tcorey
Message 2 of 5 (173 Views)
Re: Point File Formats list order
10-01-2012 03:10 PM in reply to: cbaildon001
You can sort by name in the Toolspace Settings Preview window, but not in the main Settings window.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Message 3 of 5 (171 Views)
10-01-2012 03:36 PM in reply to: tcorey
Thanks Tim.
Where the order really matters though is where the average user needs to specify the file format, which is in Import/Export/Transfer windows.
Interestingly the Export and Transfer windows have dropdown lists to specify the file format and this is in alphabetical order. Great.
But in the Import points window you get a list to scroll through which in the same random order as in the main settings window. Is there any way to change the order in this window so user can find what they want in the list easily?
Caleb Baildon
Surveyor
AllenJessup
Message 4 of 5 (148 Views)
10-02-2012 05:37 AM in reply to: cbaildon001
After you load the point file into the Import Points dialog box. Turning on Filtering will eliminate any format that does not match the delimiters found in the file. So if it's a comma delimited file all the space delimited files will be eliminated from the list.
I know this doesn't do anything for sorting but it will cut down on the choices available.
Allen
Message 5 of 5 (134 Views)
10-03-2012 01:48 PM in reply to: AllenJessup
Thanks for the replies.
Filtering does help a little but the vast majority of our formats are CSV so the list is still quite long.
I'm sure this list is supposed to sort properly, so I'll report it as a bug to be fixed.
Regards
Caleb Baildon
Surveyor
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
