Is there a way to re-order the point file format listing for points on the settings tab? I have tried everything and it will not change the order of the listing.
Not that I'm aware of. At first I thought it might have something to do with the order the format was created but that didn't work either. Two formats created right after each other, one named "aaa" and the other named "aaaa" showed up in two different places in the list.
Not sure the ryme or reason, but if you right click and go to properties, then press ok. some of the files will move in the list. it grouped the PNEZ together.
