Civil 3D Forum
Plotting of Geospatial thematic map
7 REPLIES 7
Message 1 of 8
herman.louie
597 Views, 7 Replies
ESRI SDE -> FME -> SDF with Civil 3D layer files.
Now I have a perfect themed map that looks like a design drawing with watermains in blue and points representing valves.  Ploting is next problem, design drawings are in black and white not color
It looks like CTB pen assignments in Plot style table don't effect geospatial features.
How do plot this?
7 REPLIES 7
Message 2 of 8
Murph_Map
in reply to: herman.louie
Yes, plot styles do not apply to FDO features or styles. The work around is save/export the Map/DWG to AutoCAD dwg format then plot.
Murph
Supporting the troops daily.
Message 3 of 8
herman.louie
in reply to: Murph_Map
What about using STB to control plotting?
Message 4 of 8
Murph_Map
AFAIK still will not work with STB, FDO uses a whole different render engine to display and plotting just see's it as an image type object and ignores plot styles for it.
Murph
Message 5 of 8
herman.louie
To bad, I wondering how to ask Autodesk for this type of option?
Message 6 of 8
herman.louie
Now does this map export work in model space and paper space?
Message 7 of 8
Murph_Map
When using export map to dwg format it creates autocad layers based on the feature layers, and creates the features as standard autocad entities with the color and other properties as displayed in the feature layers. Any feature labels are converted to mtext and on their own layers. All feature data is in model space and any paper space objects stay in paper space.
Murph
Message 8 of 8
herman.louie
Now the next problem, color is a RGB value and not a numbered color whick does not conform to a CTB file.  One problem after another trying to get Geospatial features representing engineering construction drawings.
Rail Community
