Civil 3D Forum
Plotting a drawing from layout produces crowded labels,
10 REPLIES 10
Message 1 of 11
JamaL9722060
1136 Views, 10 Replies
This is the second time I’m highlighting this issue. I couldn’t figure out how to print a drawing (attached) from the lay out. What I got is a very crowded drawing as shown in the screenshots below.
I wanted to print my drawings (contour, horizontal alignment, vertical alignment, etc.) in an A4 with a scale of 1/1000 or 1/1300. Then what should be:
  1. The annotation scale?
  1. The viewport scale?
  1. The plot scale?
What did I get very crowded drawing when I tried to print from the lay out?
Thank you
Best
Jamal
Jamal Numan
10 REPLIES 10
Message 2 of 11
BrianHailey
in reply to: JamaL9722060
Typically, you plot a layout tab at 1:1 and then assign the scale through the viewport/annotation scale that you have circled in your second image. Your labels are created so they plot at a specific height. For example, in an imperial drawing, a common label height is 0.1". If you are plotting a large area and you don't want to see all the labels, freeze the labels you don't want to see within the viewport.
The scale you assign the drawing in the model tab has absolutely nothing to do with how your drawing plots from paper space.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 11
JamaL9722060
in reply to: BrianHailey
Thank you BrianHailey for the help,
Plotting these drawings from the model space is perfect. Everything is drawn as it is expected. All what I needed to do is to set
  1. The annotation scale to be 1:500
  1. The plot scale to be 1:1 (to get a scale of 1/1000)
  1. Then I got perfect drawings
  1. Now at which viewport am I expected to get the same ones printed from the model space (as shown in the previous screenshots) when printing from the lay out? I do still need the labels to appear on the drawing exactly the same way they appear on the printed drawings from the model space.
Best
Jamal
Jamal Numan
Message 4 of 11
neilyj666
you always need to Regen the drawing when using viewports and as advised previously on several occasions the label height is in mm and so will always plot at 2 mm say whatever plot scale is.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 11
AllenJessup
Click on the viewport to select it. Bring up the properties box. Select the proper scale from the standard scales  This is what will control the layout scale, then plot 1:1.
Allen Jessup
CAD Manager - Designer
Message 6 of 11
JamaL9722060
in reply to: AllenJessup
Thank you guys for the help,
  • This is exactly neilyj what I need to achieve! I need all the labels to be printed with a height of 2mm irrespective to the scale of printing. Then why I got crowded labels as the scale changes? Are the scales supposed to be adjusted automatically (attached)?
  • I tired the valuable approach that you have provided Allen. Unfortunately, I do still have the crowded lables (attached)!
What might be the issue here!
Best
Jamal
Jamal Numan
Message 7 of 11
Jeff_M
Do not look at the Annotation scale for the Viewport. Look at the Viewscale of the Viewport, THIS is what controls the size of C3D labels.
Message 8 of 11
JamaL9722060
in reply to: Jeff_M
Thank you Jeff for the help,
This really very frustrating! Is it complicated to this degree just to print my drawings of C3D in the lay out
  1. My drawing looks fine in the model space and is printed correctly from the model space
  1. The issue is when printing from the lay out! I’m not sure about the best combination of plot scale, annotation scale & viewport scale that generates nice drawing (the as the one I got as I print from the model space) with not label overlaps. My dwg file attached in my first post of this thread.
Best
Jamal
Jamal Numan
Message 9 of 11
AllenJessup
I don't have access to C3D right now. I'll see what I can do when I can.
Allen Jessup
Message 10 of 11
Hi Jamal,
it's just one command you are missing in layouts, that is _REGENALL.
Every time you change the zoom-factor in the viewport of a layout (so it's the scale you are changing), do a _REGENALL to let Civil update all scale-dependend objects to the current viewport-scale on the layout.
It's nothing else then that.
[EDIT]:
Try these steps: Zoom to this table you have (in the viewport ==> then _REGENALL, next zoom more close to the table, again _REGENALL, repeat these steps as often as you like (at least as often so no other object like the surface is visible in that viewport) ... you will see that after every _REGENALL the table recalculates it's size so it is correct in repation to the papersize (of this layout)
[/EDIT]
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 11 of 11
Perfect. As usual. You are a star.  It worked like a charm
That was the little trick that I couldn’t figure it out!
Many thanks for the elaboration and the distinction between AutoCAD and C3D
Best
Jamal
Jamal Numan
Rail Community
