Is anyone else having issues plotting to PDF.....and also printing that PDF? My objects and linework get completely twisted, it doesnt make sense. Also, when I print the PDF, it does not print my transparent lines or hatch areas. MIND BOGGLED! please help.
Solved by neilyj666. Go to Solution.
Have you checked the plot transparency box? The OOTB dwg to pdf.pc3 doesn't handle transparent hatches very well in my experience and I use a 3rd party one e.g. Bullzip
your a genius! Thank you. I downloaded builzip and it worked great. What amazes me is, I bought Adobe Professional, in thoughts of the program exporting great pdf drawings from autocad. That is what the program is designed to do! crazy.
