I have a survey symbol for a tree that is created using two polyline arcs with width to make a solid circle. It is scalable in the desc key by tree size.
Sometimes when I plot a drawing the tree symbols plot (both paper and pdf) as "spokes on a tire", like a line with a polar array. (Even though the style is created with 2 polyline arcs with width)
If I explode the point object (not anywhere near ideal) then it plots as a solid circle as it should.
I don't maintain the template, I just use it, so modifying the point style isn't really an option.
I have not been able to nail down when it occurs and when it doesn't.
Any input is greatly appreciated.
I would try to work with a pline and hatch if width was not funtioning as expected. A block with a pline circle with R=1 and a solid hatch will scale fine with points and description keys.
John Mayo
