Civil 3D Forum
Please need help Depth analysis between two surface
4 REPLIES 4
2044 Views, 4 Replies
 I have two surface ( OG surface and Gravel LIFT ), i need to have a table that Show me Depths range between those two surface with a color range, in a table and also to be able to see it in the the top surface.
Basically, In every Spot of the surface, need to represent a Depth range between the OG and the gravel surface by a specific Color.
Thanks Guys.
i really need your help Guys.
4 REPLIES 4
tcorey
What you need to do is create a TIN Volume Surface. That surface will be the comparison between the other two. Simply apply Elevation syle settings and range values as you would for a normal surface, but these values will represent the differences in your two surfaces not actual elevations.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Joe-Bouza
in reply to: tcorey
...And you can add surface labels on a grid over the surface if thats the kind of thing you like.
Joe Bouza
in reply to: Joe-Bouza
Hi Guys, I thank you so much for your Help. It did Work finally. Keep up the good work Boys -- *H. Kaina*
Thanks for this.
I had been over TIN Volume Surfaces several times and didn't understand it.
My client has been asking if I could produce fill volume and lift reports and I just answered "yes" because I knew Civil 3D could do it.
All I managed to find by myself was Volumes and Minimum Distance Between Surfaces.
This is great and is another reason to not switch to Carlson!
Thanks again!
Rail Community
