Civil 3D Forum
Plan production tools problem
2 REPLIES 2
UrosIsan
415 Views, 2 Replies
Hello to everyone!
I have a problem when creating paper sheets with Plan production tools in civil 3D. When I create the corresponding sheets and layouts, dimensions (autocad elements) can not be seen in the layout mode. I use civil 3D 2011. The problem is a little bit annoying considering the fact, that dimensions are important element of plan production.
If anyone has a clue how to solve the problem,...
Thank you in advance
Tags (1)
2 REPLIES 2
castled071049
in reply to: UrosIsan
The problem may be one of annotation scales being shown in layout view. Make sure the Annotation Visibility icon (see attached) in the lower right corner of your layout desktop is clicked on. See if that helps.
UrosIsan
in reply to: castled071049
Thank you for help. I turned the annotation light on, and all the dimensions are visible. Success.
Best regards Uros
Rail Community
