AutoCAD Civil 3D General
Valued Contributor
Vasily_BC
Message 1 of 5 (327 Views)
Accepted Solution
Plan and Profile layout
327 Views, 4 Replies
04-30-2012 04:41 PM
Is there any chance to fit plan and profile on one 11x17 layout without exploding and export to dwg?
I can't do it because of annotation scale that change every time.
Thanks.
*Expert Elite*
sboon
Message 2 of 5 (313 Views)
Re: Plan and Profile layout
04-30-2012 05:49 PM in reply to: Vasily_BC
Sure - we do it every day.  But we need a lot more information to comment intelligently on what you're trying to do.  Are you trying to plot a D size sheet at 1/2 of it's normal size or are you trying to create a new layout for a drawing that was originally built for a larger sheet?
*Expert Elite*
LisaPohlmeyer
Message 3 of 5 (296 Views)
05-01-2012 05:15 AM in reply to: Vasily_BC
We create our 1+ mile roadway plans on 11x17 at 50 scale.  My roadway template viewports are set for 50 scale so that when I use the Plan Production tools, the sheets are scaled appropriately.  You should check out the tutorials on using the Plan Production features.
Lisa Pohlmeyer
C3D 2012 SP4, evaluating C3D 2015
Please use "Accept as Solution" if this solved your issue.
Valued Contributor
Vasily_BC
Message 4 of 5 (281 Views)
05-01-2012 09:41 AM in reply to: sboon
Here I have 1:1000 annotation scale and 1:5000 viewport scale. I have whole alignment here and profile, but I think it was made by using different method, because all features aren't blocks.
Can I turn off connection of annotation with viewport scale somehow?
Valued Contributor
Vasily_BC
Message 5 of 5 (187 Views)
07-06-2012 02:15 PM in reply to: Vasily_BC
What I've needed is just change some styles settings for profile!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
