Is there any chance to fit plan and profile on one 11x17 layout without exploding and export to dwg?
I can't do it because of annotation scale that change every time.
Thanks.
Solved by Vasily_BC. Go to Solution.
Sure - we do it every day. But we need a lot more information to comment intelligently on what you're trying to do. Are you trying to plot a D size sheet at 1/2 of it's normal size or are you trying to create a new layout for a drawing that was originally built for a larger sheet?
We create our 1+ mile roadway plans on 11x17 at 50 scale. My roadway template viewports are set for 50 scale so that when I use the Plan Production tools, the sheets are scaled appropriately. You should check out the tutorials on using the Plan Production features.
I'm trying to get something like this
Here I have 1:1000 annotation scale and 1:5000 viewport scale. I have whole alignment here and profile, but I think it was made by using different method, because all features aren't blocks.
Can I turn off connection of annotation with viewport scale somehow?
