When creating plan and profile sheets is it possible to create the plan view with the alignment moved down to show more of project above the alignment? The default setting puts the alignment at the center of the plan view window.
To handle this ahead of time, move your view frame. If you want to do it later, just pan within the viewport that was created on the sheet's layout tab.
Oops, I spoke before I tested. You can't Move the view frame with the Move command. You have to use the square grip that appears after you select the frame.
