Hello there,
Is there anyway to get a plan plan rather than plan profile in plan production.
Any advice will be appreciate.
Thank you.
Also hopefully we can produce a profile profile also.
Thank you in advance.
Not sure that I understand what you're looking for here. Do you want to create a sheet drawing that has two plan views or two profile views on the same layout?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I can think of a couple of ways to do it. In the template drawing below I have created one magenta viewport in the top half of my layout. The bottom half has a polyline X shape in it as a placeholder. If I used this template to create plan view sheets with multiple layouts in one drawing I would get one view per sheet. Once I have the sheets it would be fairly simple to cut and paste the viewport from layout 2 to the bottom half of layout 1. Repeat as many times as necessary, delete the extra layouts, then renumber and update the titleblocks as necessary.
The same procedure would work for profiles also.
Steve
You can create a plan sheet OR a profile sheet using the appropriate template: see this from 2013 user guide:
