AutoCAD Civil 3D General
Member
Message 1 of 6 (176 Views)
Pipeworks to SDF
176 Views, 5 Replies
08-01-2013 08:10 AM
Trying to export pipeworks data that I have imported from a GIS shapefile, modified to reflect field conditions and now trying to get back out to another shapefile. From what I have read the way to do that is by exporting to SDF and then to a shapefile format. This all works fine and dandy but for some reason in the SDF export process it has added 1/2 the pipe diameter to the pipe inverts. For example one pipe end has a invert of 433.74 on an 18" pipe. In the SDF file table it is now 434.49 or plus 0.75'. I'm using the default Civil_Schema.
Any idea what is going on here?
Member
Message 2 of 6 (127 Views)
Re: Pipeworks to SDF
08-05-2013 01:42 PM in reply to: cmorris
....(.sound of crickets).........
*Expert Elite*
Message 3 of 6 (117 Views)
08-06-2013 01:49 PM in reply to: cmorris
You may have answered your own question:
"Any idea what is going on here?"
Nope. Not a clue what you're talking about, sorry.
Isn't GIS & shapes more of a Map thing? Maybe ask over in the map forum.
http://forums.autodesk.com/t5/AutoCAD-Map-3D/bd-p/85
Credit where credit is due! Give kudos or accept as solution whenever you can.
Member
Message 4 of 6 (114 Views)
08-06-2013 02:00 PM in reply to: cmorris
Well I did consider posting it there but the function to export Civil Objects to SDF is wholly within Civil 3D and the only thing exported is Civil objects such as pipeworks, alignments, surfaces, etc. Once the gis data is imported its just a pipe network as far as I know.
Product Support
AlmasSuljevic
Message 5 of 6 (86 Views)
08-14-2013 05:06 AM in reply to: cmorris
Can you try exporting to SSA and then SSA can export to SHP file? Will that work better?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Member
Message 6 of 6 (62 Views)
09-04-2013 11:40 AM in reply to: cmorris
An update to my perdicament. Well as noted it does in fact use the centerline of pipe on the export to SDF and reports it as the invert. This issue has been "escalated to the development team to investigate further" based on my customer support request.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
