See attached. How do I get the pipe properties tp default to what I tell it to? I looked in the parts list, but did not see a place to set the description of the pipe. So when I add pipes it is getting the description hilghted in dark blue on the attached image. I want it to say (in this case) "8" PVC," not "PVC Pipe."
Can anyone tell me where the setting is?
thanks.
Solved by Jeff_M. Go to Solution.
By default C3D uses the Part Family as the Part description, there was an explanation of 'why' back in 2010. There is an option under Pipe Network Feature Settings to allow the use of the Part Size Name as the description.
Glad I could help. Please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. It also lets the folks at Autodesk know that your question has been answered, as they are trying to be sure to respond to posts which have gone unsolved after a period of time. Thanks!
