Civil 3D Forum
Pipes in Profile Display Incorrectly
3 REPLIES 3
schroeder.a
441 Views, 3 Replies
Hi All,
I've got a weird problem with pipes in 2014.  When I edit a pipe (right-click Pipe Properties) and make a change, when I press OK or Apply, the pipe SIZE changes?  It's still listed as a 300mm PVC, but it's being represented as a 410mm?  Look at the attached image.  The storm (green) shoes a 300mm pipe and 375.  The 375 is smaller?  THe pipe style (as you can see int he image, is set to displae the inside pipe walls.
Nothing is unique here about the pipe sizes, this is a stock pipe catalog.
But the size doesn't really change, only how the pipe is drawn in the profile.  I've never seen something like this before.  It measures .418m instead of .3m.
Andrew
3 REPLIES 3
troma
in reply to: schroeder.a
Is this reproducible with different pipes and in different drawings?
What specifically are you changing in the pipe properties?
Mark Green
Working on Civil 3D in Canada
BrianHailey
Perhaps turn off the crossing pipe outside wall?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
schroeder.a
in reply to: troma
I was chanigng pipe slope - but the solution here seemed to be re-pathing the part catalog to our network location.  The version we had it pointing to after installation was causing it to replace the part.
Rail Community
