Civil 3D Forum
Pipes Labels North, East, South West Direction
10 REPLIES 10
Message 1 of 11
gtimmerman
1599 Views, 10 Replies
My question of the day
Does Civil3D have the capability to label the in and outflow pipe direction into a structure? If it does can somebody show me the way to get there.
Gerrit Timmerman
10 REPLIES 10
Message 2 of 11
in reply to: gtimmerman
The closest thing to this is "Pipe Start Direction in Plan" and "Pipe End Direction in Plan". However, this is for Pipes, not structures.
Another alternative is to create a structure label style where you free form the text for structures. If the value you use for the text string is common, or just a few variations, then this could work for you. If you are listing an actual bearing or direction, the the first method above may work.
Give it a shot!
Message 3 of 11
"Connected Pipe Direction" will give you the location of the connected pipe in relation to north. (n,s,e,w,ne,nw,se,sw)
Message 4 of 11
gtimmerman
Thanks for the input.
It did the trick
GT
Message 5 of 11
where is the "connected pipe direction"? I don't see under the properties of Pipes or structures.
Message 6 of 11
gtimmerman
It is part of your label style.
Go to your label style composer.
Add a "Text for Each" component to your style.
You will find "connected pipe direction" under Text contents.
GT
Message 7 of 11
In the label composer for structure labels there is a component named "text for each" (in addition to the normal text, line, block components) Here you can chose a component for labelling the connected pipes, and with this component you get some more labeling properties. One of them id the connected pipe direction.
I have a question, if anyone out there might know, How does C3D decide the order in which it displays the connected pipe information? Example: I would like it to list the incoming pipe inverts in order of their elevation, highest first.
Message 8 of 11
It was the "text for each" I missed. Thanks.
Message 9 of 11
I believe the "connected pipe direction" is based on the World coordinate system / true north. Just wondering if there's a setting / way to get those labels done with construction north. I can't find a way to get this done by expressions.
Thanks in advance
PJ
Message 10 of 11
Can this be done with a Grid Rotation in the Transformation tab of the
Drawing Settings dialog?
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5445378@discussion.autodesk.com...
expressions.
Thanks in advance
PJ
Message 11 of 11
Thanks John
I've tried the suggestion but no luck 😞
Rail Community
