Civil 3D Forum
Pipes: Continue drawing a pipe from the existing elevation of another pipe?
4 REPLIES 4
mhvam06
506 Views, 4 Replies
Hello everyone!
Is it possible to draw a new pipe from another pipes elevation that has already been drawn?
When I draw pipes using Network Layout Tools it creates a Null structure in which the elevation of the new pipe is higher than the connecting pipe.
I have tried adding the rule "Pipe to Pipe Match" with the following:
Match Location: Centerline
Drop Value: 0
But it is still not spot on even though the pipes are the same dimensions. For some reason it is 6 mm off...
I think it's a bit annoying that I have to create a profile view of the pipes and structure in order it change the pipes to the correct elevation. Using pipe properties is unfortunately not accurate enough.
All the best!
Mike
4 REPLIES 4
kcobabe
in reply to: mhvam06
Go into the structure properties->connected pipes tab-> Select a pipe and right click-> Select the match you want.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
mhvam06
in reply to: kcobabe
Thank you very much for your solution kcobabe!
I does make it a lot quicker than the before mentioned create alignment,
profile and then change to connections.
However if there are a quicker and a solution using fewer clicks I would
be glad to hear it!
As of now I will stick with kcobabe's solution.
Thank you!
kcobabe
For the most part having a good set of rule definitions help a lot.  There is another tricky way to do it.  If you are a 3D kind of person you can grip edit in 3D.  I have one word of caution though, Save Often, C3D even though the name suggest 3D it's still not a true CAM/BIM modeler.  So it hates working in a true 3D presentation.  Crash crash crash craaaaaash!!
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
mhvam06
I'll stick to 2D when I'm drawing then 🙂
The before mentioned solution does make it a lot quicker to draw pipes and set them to the correct elevation.
Thanks a lot!
I'm still working on my rules in order to make C3D more efficient.
Would it be much trouble for you to list your pipe and structure rules? Maybe as a screenshot?
Do you by any chance know why the "new" pipe is not spot on when I use this rule:
Pipe to pipe match
Match Location Centerline
Drop Value 0
It is the same network and dimension. For some reason it is off my about 4 mm.
Cheers
Rail Community
