AutoCAD Civil 3D General
Active Member
hdn9298
Message 1 of 7 (2,062 Views)
Pipe structure won't show up in profile view
2062 Views, 6 Replies
02-22-2012 04:39 AM
I've been having a problem with a pipe structure not showing up in a profile view.  I have a single pipe network with everything (pipes and other structures) showing up in the profile when I select them, right-click, and click on "Draw Parts in Profile".  Like I said, this works for all the other pipes and structures in the profile except one.  When I select the structure individually and try to draw it into the profile, it still won't work.  A friend told me to make sure that the structure is within the surface, and it is.
Any thoughts on this?  I'm using AutoCAD Civil 3D 2011.
Thanks.
Message 2 of 7 (2,052 Views)
Re: Pipe structure won't show up in profile view
02-22-2012 06:03 AM in reply to: hdn9298
Hi hdn9298,
I don't mean to be simplistic, but a few things come to mind: Is the structure within the limits of the alignment/profile?  If the structure has a different style than the others (an override), is that style configured to show in profile view?   Also, if the alignment doubles back on itself, the software has been known to get confused on exactly which station the structure is at.  If you want to send me the drawing, I can take a look.
Scott Kent P.E.
Senior QA Analyst II
IPG – Information Modeling
and Platform Products Group
100 Commercial Street
Manchester, NH  03101
scott.kent@autodesk.com
Scott Kent P.E.
Infrastructure Collaboration Products
Joe-Bouza
Message 3 of 7 (2,047 Views)
02-22-2012 06:48 AM in reply to: scottkent
To add to Scott's suggestions: does the structure properties indicate the expected surface elevation?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
wfberry
Message 4 of 7 (2,043 Views)
02-22-2012 07:28 AM in reply to: hdn9298
My guess is that the structure in question is at one end or the other of your alignment, and the alignment does not go beyond the structure.
Bill
jmayo
Message 5 of 7 (2,038 Views)
02-22-2012 08:11 AM in reply to: hdn9298
You can also check to see if the stc has a 'hidden' style override assigned in the profile view.
Profile View Properties dialog, pipe networks tab. Locate your stc and go to the last column. See if an override is assigned.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Active Member
hdn9298
Message 6 of 7 (2,030 Views)
02-22-2012 11:28 AM in reply to: Joe-Bouza
Thank you, everyone, for the suggestions.  It turns out that Mr. Bouza made the suggestion that solved the problem.  The insert rim elevations were set too high, beyond my profile's scale.  Thanks again, I was at a loss over what was happening, but now I know to check the elevations!
Joe-Bouza
Message 7 of 7 (2,023 Views)
02-22-2012 01:51 PM in reply to: hdn9298
HTH.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
