I have a plan & profile sewer project that I'm taking over on from a previous employee. Every time I make pipe network changes and synchronize, the pipes disappear (only in the profile) but all the notes remain. I have to re-select all the pipes and tell it to draw in profile view every time. I can't keep doing this!
Solved by ccoady. Go to Solution.
i have this problem in 2011, although it does not disappear everytime. Almas suggested putting the pipes/structures in profile views in locked layers, which definitely helps.
I'll try locking the profile layer. That makes sense. I've had this problem before on cross sections and that was A solution as well.
Well, locking the layers didn't work. Damnit....
I ran the "audit" command, and it found and fixed 5 errors. Now everything works fine. That was simple enough.
