Hello.
I'm very new to Civil 3D and I'm confused.
I have been asked to convert a 2D drawing into a 3D drawing that will be used for BIM (and I'm new to that term as well). So I am creating pipe networks for the existing utilities with x' of existing cover.
What I am running into is that there are too many segments in the pipes that I'm creating even after weeding. For instance, I have a pipe that is about 200' in length and have about 15 segments. That would be fine with me, but is there some way that I can tell Civil 3D to treat it like one long pipe instead of adding null structures to every single segment? I want to be able to select the pipe and have it select the entire length instead of that single segment.
Another reason why I want it to be a single segment is because in plan view my linetype doesn't properly show up since the segments are too many and their lengths are too short to show the linetype. When creating a 2D drawing, a polyline can be set with linetype generation enabled so the linetype is shown in this case. But what do I do about this in Civil 3D pipe networks?
I appreciate your help.
Mark
Ps. I found a video that mentioned to create a polyline with the layout that I want, then apply elevations from suface, convert it to a feature line, then covert to a pipe network. Supposedly, that would "connect" the pipes and structures together. I tried this technique but it doesn't do what I'm looking for.... I suppose when he says "connect," he may have a different meaning that what I was hoping for.
Solved by mathewkol. Go to Solution.
Sounds like you're making pipes from existing polylines. If your pline has multiple vertecies, you will have multiple pipes and multiple stuctures. That's how that tool works. There is no such thing as a single pipe with multiple vertecies.
[... I want to be able to select the pipe and have it select the entire length instead of that single segment...]
This is not possible.
Matt,
I appreciate your response. I'm glad to at least know not to waste any more time trying to find a solution.
Mark
I am trying to convert polylines into pressure pipes. the only way I know is to convert it one by one. I have a huge pressure network and this method is taking a lot of time. Is there any other way we can convert multiple polylines into pressure pipes at once?
Thank you in advance!
You might get better advise if you had mentioned pressure pipes in the beginning. C3D has both pipe network or gravity pipes and a separate pressure pipe tool.
Avoid the extra point - Use the plines as a guide and draw pipe network directly
Your Name
Your Name
