You can extract pipe elevation information in plan view, but it requires a little prep work first. The main thing you will need is a defined Profile by Layout that follows whatever part of the pipe you wish to extract information from (i.e. crown, invert, top of pipe, etc.) Once you have that defined, you can construct a plan view label that accesses the elevation of the defined profile at any point.
Note, though, that this label is dynamic to the defined profile, NOT the pipe network. In other words, if you make changes to pipe inverts, the label will not update until you re-snap the defined profile to the newly edited pipe.
This sounds like a lot of work, and feels like a workaround, but once you have the label constructed and place it in your base template, you can quickly use it again and again.
