Civil 3D Forum
Pipe network Structures table with invert out
7 REPLIES 7
Message 1 of 8
cadconfused
2773 Views, 7 Replies
I have a pipe network and I made a structure table for that pipe network.  One of the columns I am attempting to display the invert out of the structure.  Right now the Text Component Editor has
<[Connected Pipe Invert Elevation(Uft|P2|RN|AP|GC|UN|Sn|OF)]>
The problem is if the structure has multiple connected pipes it pulls 1 of the pipe inverts and displays, which is usually any upstream invert.  If the structure only has 1 pipe connected it will give me that invert, which is the generally the downstream invert of an inlet.  I want to be able to display the Down Stream Invert, has anyone been able to accomplish this?
Thank you for the help.
7 REPLIES 7
Message 2 of 8
cadconfused
in reply to: cadconfused
No one has any ideas?
Message 3 of 8
BrianHailey
When you add the column to the table, remove the default component and add in a "Structure out flow pipes" component.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 4 of 8
cadconfused
in reply to: BrianHailey
Ok I did that and I get this as my table
Why am I getting multiple inverts showing up?  Does that mean some of the directions of my pipes are drawn in incorrectly?
Message 5 of 8
BrianHailey
Don't know. Can you share the table style and the pipe network? Remember, just because a pipe is the lowest elevation doesn't mean it's the outflow pipe. Pipes have both direction and flow direction.
GEI Consultants
My Civil 3D Blog
Message 6 of 8
cadconfused
That is probably the issue at this point.  I can share the style and network but how do I get it into a format you could see or I could send in an attachment?
Message 7 of 8
cadconfused
I did have some pipes that had the wrong flow direction.  Thank you for the help I was able to get it working now.
Message 8 of 8
BrianHailey
Awesome! Good to hear!
GEI Consultants
My Civil 3D Blog
Rail Community
