I hate this program. It's working fine one second and then it stops working.
For example: I'm creating a utility template. Earlier in the day, I'm able to assign pipe and structure rules to a network and create the network based on these rules. Within the past 30 minutes, however, it completely ignores the pipe and structure rules while creating the network. I'm doing absolutely nothing different than earlier in the morning. I'm even following the same alignment!!!!!
I make sure there is a surface assigned to the network. I make sure the pipe rules are set correctly in the parts list. I'm using no null structures. NOTHING HAS CHANGED EXCEPT THE POSITION OF THE MINUTE AND HOUR HANDS ON THE CLOCK! It's like the Civil 3D went out to lunch and forgot to tell me that it's going to lunch.
Fred
-Civil 3D 2012
-intel Core i7 2.4 GHz
-8 GB of RAM
Windows 7 64-bit
Solved by Cre9engr. Go to Solution.
I found my problem. The rule sets were applied correctly, but somehow, the rules themselves were deleted.
