Show only
Search instead for
Ok so I am having this problem where in my profiles the invert lables are there but if I try to edit the invert elevation through prospector it is adding .02 thickness of the pipe to my invert label. So when I enter the invert in the chart the label is not the same as what I entered (the adding .02 thing)
We always consider the invert of the pipe to be the inside and not the outside. Is there some setting some where that tells it to add the pipe thickness to get the invert?? Am I missing it?
Well that blew my theory of the label showing the floor elevation of the structure which accounts for pipe wall thicknesses.
The invert label, is it part of a pipe or a structure label?
Is the invert difference you see exactly equal to the pipe wall thickness?
The "chart" you reference in the original post, is that the pipe properties dialog?
Any other info you can offer sill help to track down the cause of the issue. (like a screen capture of the pipe properties and the label style settings for the invert)
The label is attached to the pipe. And Yes the difference is exactly .02 everytime. The strange thing is sometimes it only affects the invert in and not the invert out so its not consistent. I will send another reply with the screen shots when ready.
It sure sounds like your file may be "tainted". Is the UCS ok? What if you
test it in another drawing file.
Bill
wrote in message news:5050373@discussion.autodesk.com...
The size limit for attachments in this forum area is 1.5 mb, however, the is another area, "customer files", where I've seen some uploaded files larger then that.
or you could send it directly to me, MMccall at geller-sive.com
