Civil 3D Forum
Pipe catalogue error - "structure size does not exist"
14 REPLIES 14
Message 1 of 15
339 Views, 14 Replies
See attached png.  Has anyone had this
problem?  I looked at my catalogue and it appears that the structure size
does exist and that the correct network parts list is referenced.  Only one
structure is providing the error so far.  I'll just erase/replace, but I
don't want all of my structures to suddenly go missing due to this unexplained
error.
14 REPLIES 14
Message 2 of 15
Wesley Price
Civil 3D 2008, SP1
Dell Precision
PWS390
Intel core 2 CPU 6600 @ 2.4GHz
2 GB of RAM
XP Pro
SP3
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
one structure is providing the error so far.  I'll just erase/replace,
but I don't want all of my structures to suddenly go missing due to this
unexplained error.
Message 3 of 15
I think with Civil 3D, unexplained error messages are becoming a way of life. I get alot of messages like that, and they never amount to anything. I'd suggest just keep working.
Message 4 of 15
Yes, Wesley, I am getting the same message.
Glad someone asked, I have been ignoring it, but was sure I had done something
wrong.  Seems strange I am using a pre-defined manhole and get a message
like that.
Bill
Wesley Price
Civil 3D 2008, SP1
Dell Precision
PWS390
2 GB of RAM
XP Pro
SP3
size does exist and that the correct network parts list is referenced.
Only one structure is providing the error so far.  I'll just
erase/replace, but I don't want all of my structures to suddenly go missing
error.
Message 5 of 15
At your command line type PARTCATALOGREGEN, select the pipes options and
when they're finished select the structures.
Lisa Pohlmeyer
DC CADD - Austin, TX
Civil 3D 08
Intel P4 2.0, 2Gb RAM
Nvidia Quadro Fx Go1400 256Mb
Wesley Price wrote:
> See attached png. Has anyone had this problem? I looked at my
> catalogue and it appears that the structure size does exist and that the
> correct network parts list is referenced. Only one structure is
> providing the error so far. I'll just erase/replace, but I don't want
> all of my structures to suddenly go missing due to this unexplained error.
Message 6 of 15
That worked. Thanks. Is the error due to 2008 install therefore parts
catalogue needs a regen?
Wesley Price
Civil 3D 2008, SP1
Dell Precision PWS390
2 GB of RAM
XP Pro SP3
"Lisa Pohlmeyer" wrote in message
news:5682555@discussion.autodesk.com...
Lisa Pohlmeyer
Civil 3D 08
Message 7 of 15
> Wesley Price
> Civil 3D 2008, SP1
> 2 GB of RAM
> XP Pro SP3
Not exactly sure, but I had a colleague provide me with some additional
parts and this was the way to rebuild the catalog.
Lisa Pohlmeyer
Civil 3D 08
Message 8 of 15
do you have a custom part in your catalog? this error is due to a problem with the equations used to define the part. There is a conflict with the calcs (a circular ref, or something like that).
Mark
Message 9 of 15
Error was specifying that a "structure size does not exist". I have no
custom structure parts or sizes. Catalogue regen solved this problem. I
had never seen the error message before our change from 2007 to 2008 and
have no further explanation.
wrote in message news:5690042@discussion.autodesk.com...
Mark
Message 10 of 15
some weird thing happened.
if i go through toolspace into the setting tab, to the pipe network, parts list, i have all my pipes and structures.
if i go into the drawing, right click on a pipe pr structure and try to swap part, it is BLANK.
any idea whats happening here ?
Message 11 of 15
I haven't encountered that problem. I would check that the catalogue is
pathed correctly and do a catalogue regen (PARTCATALOGREGEN).
wrote in message news:5692869@discussion.autodesk.com...
part, it is BLANK.
Message 12 of 15
Civil3D Groupies
That's happened to me before. Ha ha.
Message 13 of 15
Civil3D Groupies
I think if I saw the file I would remember how I resolved the issue.
Anyhow, a temporary fix, you could create a new parts list, add the parts you want to swap to.
Then you may need to set the pipe network to the new parts list. Which is in network properties, the layout settings tab and there you will find the associated parts list.
After that, when you swap parts it should appear.
Let me know if that helps.
Message 14 of 15
thats outrageous, cant be swapping umpteen parts,
how is wrk for michael baker treating you.
you got an email. i have questions on the road profile setups you "setup here"
Message 15 of 15
Civil3D Groupies
swapping many parts? i guess than it won't work so well.
hmmm, i only had a few to do, so it worked for me, it swapped all manholes at once.
Rail Community
