I want to create a 96" RCCP pipe designation for labelling purposes. For what we are doing jsut changing the name of the 96" RCP would work fine. Is there a way to change the name of pipe in order for the labelling with show up as a RCCP vs RCP.
Solved by jmayo-EE. Go to Solution.
SAelect the pipe. Right click and choose pipe properties. Go to the part properties tab. Scroll down to the bottom and you should see a field for material. Change RCP to RCCP.
OR
Setup a new pipe label style that displays the pipe desc vs the material and you can edit the desc to read RCCP or anything you want.
John Mayo
Thank You. I have a drawing where in the pipe properties the pipe type will not change for some reason which is why i was asking. Works fine in a ll other drawing. Glitch in drawing I guess.
I've been having some serious issues with pipe materials in 2015. Prior to the service pack, you couldn't set the material when adding a part to the parts list and after the service pack (SP1) the option to choose the material is not there at all.
Works fine in 2014 however.
