AutoCAD Civil 3D General
Joe-Bouza
Message 1 of 4 (974 Views)
Pipe Styles
974 Views, 3 Replies
03-23-2011 12:42 PM
I can't believe I haven't encountered this yet. I have a drawing with a couple of profiles and some pipe networks. One alignment is collinear with the pipe network and another crosses the networks. I want to show the pipe crossing as well as the longitudinal on it companion alignment. If I set the profile setting for the pipe display to show the pipes crossing I don't get the longitudinal and if I try to assign the different style to the crossing pipes the plan view disappears. So, how should I set my styles to get a crossing pipe and a longitudinal in the same file?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Jeff_M
Message 2 of 4 (968 Views)
Re: Pipe Styles
03-23-2011 01:11 PM in reply to: Joe-Bouza
Create a style for the crossing display. Assign this style to the pipe's Style Override in the ProfileView properties Pipe networks tab.
Joe-Bouza
Message 3 of 4 (952 Views)
Re: Pipe Styles
03-23-2011 03:32 PM in reply to: Jeff_M
Perfect. I was lookig for something like that but couldn't see through my panic :smileyvery-happy:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Active Contributor
cfiorica
Message 4 of 4 (530 Views)
Re: Pipe Styles
07-19-2012 10:33 AM in reply to: Joe-Bouza
This also helped me with a different problem I was having (so far at least).  I would change the pipe style to my XING pipe style, save and leave the drawing.  When I opened the drawing...all my xing's had changed back to a non-xing style!  I tried it with the override and so far the styles seem to stick.  This tip would have come in handy on another drawing long since gone now.  Thanks!
Carl M. Fiorica, P.E., LEED A.P.
Burkett and Wong Engineers
3434 4th Ave
San Diego, CA 92103
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
