I am trying to label a Catch Basin. I have added the part as a basic cylindrical structure, and then changed the name to "CB".
My style uses the <Part Size Name(CP)>, which I would have to believe is the name that I changed the part to, but the label shows up with the original name "Slab Top Cylindrical Structure... and lists all the sizes".
Is this the proper way the label works? or do i need to go into my Network Part list and change things there?
Solved by Bill_Myron. Go to Solution.
I could not find that Label property in the list. Maybe it si included in 2012?
I did find a much better way to do this though.
In parts builder, I changed the value of SF (Frame) to the types of frames I use.
Secondly, I changed PrtSN to what ever Frame I select.
So now when i add the part, The description comes up with the frame, which is exactly what I need. This also makes my parts list a little more easy to control.
I said Name property not Label property.
