AutoCAD Civil 3D General Discussion
Active Member
dave1001
Message 1 of 5 (628 Views)
Pipe/Structure Table
628 Views, 4 Replies
08-19-2011 09:03 AM
I am trying to create a table that will incorporate info from structures and pipes.  In C3d 2010 I want to make a CB chart which will show the pipe size, starting structure and invert.     I would also like to include the CB rim elevation but that would be under the structure table.  Is there any way I can combine the RIm elevation with  the pipe table?
Valued Mentor
engineer4life1979
Message 2 of 5 (619 Views)
Re: Pipe/Structure Table
08-19-2011 09:20 AM in reply to: dave1001
you can create a structure table style with structure RIM, SUMP etc. and then add to it the components for the connecting pipes (see attached). does that get you what you need?
download the attachment, rename to remove the ".txt" portion, then you can view it in internet explorer. you may have to allow the content.
Civil 3D 2013 SP1, Win 7-64 bit
12GB RAM
Active Member
dave1001
Message 3 of 5 (609 Views)
08-19-2011 09:38 AM in reply to: engineer4life1979
that's exactly what I was looking for.  Thank you very much
bbuye03
Message 4 of 5 (216 Views)
05-22-2013 10:42 AM in reply to: dave1001
What about adding the "pipe length" of the connected pipe to that structure table?
B.
New Member
jwehling
Message 5 of 5 (156 Views)
09-12-2013 06:04 AM in reply to: dave1001
I'm having the same needs in 2012 Civil 3D - to combine specific structure and pipe table items into one table, but the progam has separated these two entities. Autocad makes it so difficult to do the easiest tasks. Tasks which are used in everyday civil engineering. It's become obvious that there isn't one experienced civil engineer advising autodesk programers as to whats needed on civil engineering plans.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
