I am trying to create a table that will incorporate info from structures and pipes. In C3d 2010 I want to make a CB chart which will show the pipe size, starting structure and invert. I would also like to include the CB rim elevation but that would be under the structure table. Is there any way I can combine the RIm elevation with the pipe table?
you can create a structure table style with structure RIM, SUMP etc. and then add to it the components for the connecting pipes (see attached). does that get you what you need?
download the attachment, rename to remove the ".txt" portion, then you can view it in internet explorer. you may have to allow the content.
I'm having the same needs in 2012 Civil 3D - to combine specific structure and pipe table items into one table, but the progam has separated these two entities. Autocad makes it so difficult to do the easiest tasks. Tasks which are used in everyday civil engineering. It's become obvious that there isn't one experienced civil engineer advising autodesk programers as to whats needed on civil engineering plans.
