AutoCAD Civil 3D General
Distinguished Contributor
ARC0112358
Message 1 of 7 (235 Views)
Accepted Solution
Pipe Properties Inner Pipe Diameter Units
235 Views, 6 Replies
01-15-2014 06:14 AM
I have been poking around for this for some time and it is eluding me...
In Civil 3D 2014, Pipe Properties, my Inner Pipe Diamter is showing units in Feet, but I want them to show units of Inches.  For example, an 18" pipe is listed as a 1.5' pipe, a 24" pipe a 2' pipe, etc....
The parts list is all in inches...
What am I missing?
Thank you!
*Expert Elite*
Jeff_M
Message 2 of 7 (228 Views)
Re: Pipe Properties Inner Pipe Diameter Units
01-15-2014 06:20 AM in reply to: ARC0112358
Is this in a label that it is showing in feet?
Jeff_M, also a frequent Swamper
ARC0112358
Message 3 of 7 (221 Views)
01-15-2014 06:32 AM in reply to: Jeff_M
No, just in the Pipe Properties, see attached screen.
*Expert Elite*
Jeff_M
Message 4 of 7 (214 Views)
01-15-2014 07:28 AM in reply to: ARC0112358
I can't duplicate this right away. I will do some digging around....
*Expert Elite*
Jeff_M
Message 5 of 7 (212 Views)
01-15-2014 07:30 AM in reply to: ARC0112358
david.zavislan
Message 6 of 7 (165 Views)
01-16-2014 08:47 AM in reply to: ARC0112358
That is controlled in the Drawing Settings.  It can be found on the Ambient Settings tab in the Dimension category.  Change the unit from foot to inch.  This will set it for the entire drawing file. If it just pipes that you want to change this for, edit the dimension unit property in the pipe feature settings.
David Zavislan, P.E. | Wood Rodgers, Inc.
ARC0112358
Message 7 of 7 (155 Views)
01-16-2014 10:11 AM in reply to: ARC0112358
That was it - thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
