Civil 3D Forum
Pipe Properties Inner Pipe Diameter Units
6 REPLIES 6
ARC0112358
1725 Views, 6 Replies
I have been poking around for this for some time and it is eluding me...
In Civil 3D 2014, Pipe Properties, my Inner Pipe Diamter is showing units in Feet, but I want them to show units of Inches.  For example, an 18" pipe is listed as a 1.5' pipe, a 24" pipe a 2' pipe, etc....
The parts list is all in inches...
What am I missing?
Thank you!
6 REPLIES 6
Jeff_M
in reply to: ARC0112358
Is this in a label that it is showing in feet?
ARC0112358
in reply to: Jeff_M
No, just in the Pipe Properties, see attached screen.
Jeff_M
I can't duplicate this right away. I will do some digging around....
Jeff_M
david.zavislan
That is controlled in the Drawing Settings.  It can be found on the Ambient Settings tab in the Dimension category.  Change the unit from foot to inch.  This will set it for the entire drawing file. If it just pipes that you want to change this for, edit the dimension unit property in the pipe feature settings.
David Zavislan, P.E. | Wood Rodgers, Inc.
ARC0112358
That was it - thank you!
Rail Community
