Back to the original question and the response of making them all one
network. How does this work with references? We have over half of a city
that we are working on so we have to break it up into parts. If all of the
pipes in the different drawings are on same name network, will the pipe
references work?
Chris
"Dana Breig Probert" wrote in message
news:5346839@discussion.autodesk.com...
I make many baselines in one corridor and hence build one surface.
Alternatively, (but this is messy because sometimes when roads come together
if they are not the same corridor they dont marry nicely and you wind up
with lots of boundaries and stupidity) copy your EG surface using autocad
copy, then paste the corridor surfaces into the copy of EG. if they change,
this new composite FG changes, too.
Regardless of how you get the corridor surface, make a composite FG.
Usually this is how I do that:
1) autocadcopy EG
2) rename that copy to composite FG
3) make isolated mini surfaces for design elements- like a corridor surface,
pond surfaces, grading pads surfaces, etc
4) paste those mini surfaces into the composite
5) use the composite as your target for structures
that composite doesnt have to be complete or perfect- in fact, often it is
just a copy of my EG when I first start. as you add more, that surface will
update.
Here are some posts and pictures that might help you.
http://www.civil3d.com/index.php/2006/09/corridor-daze/
http://www.civil3d.com/index.php/2006/09/increasing-drawing-performance-when-working-with-large-corridors/
http://www.civil3d.com/index.php/2006/09/a-civil-3d-portfolio/
http://www.flickr.com/photos/civil3diva/sets/72157594291966137/
For the selection of many pipes at once, I dont have captures handy, but
anything in prospector can be selected in a group. See the first entry in
this post called "The Batch Style Swap" it also works for batch swapping
alignment and surfaces for pipes/structures
http://civil3drocks.blogspot.com/2006/07/things-that-even-civil-3d-super-heros.html
Dana Breig Probert, E.I.T.
Engineered Efficiency, Inc.
www.civil3d.com
www.eng-eff.com
Civil 3D 2007 SP2
AMD Athlon 64 X2 Dual Core 2.01 GHz
2GB RAM, 256 MB ATI FireGL V5200
