Could you give an example of what you are referring to as "style"? There
are 14 different classifications of structure labels.
Go to Toolspace ->Settings -> Structure -> Label Styles ->
Standard ->(Rt.Click, edit) -> Layout Tab -> Text Contents
Select the Value column of the Contents [ellipsis] , under Properties, there
are the 14 different labels.
Not sure if this is what you are looking for.
Bill
wrote in message news:5042755@discussion.autodesk.com...
Is there a way change the default Discription. Right now it label the size
and shape? I would like it to label the structure style.
any help would be great
