Civil 3D Forum
Pipe Network
1 REPLY 1
460 Views, 1 Reply
Pipe Network
I want to connect two rain water pipe networks at a junction (T- Junction) , both runs from different direction, say , 1st line runs East to West and 2nd line South to North meet at the mid of  1 st line makes a T- junction, from that T loaction  it has to be single network upto the Rainwater storage tank (towards north).
So how do i connect at 'T'?  When i use the option Modify > Connect Part  A " warning mssg says that cannot connect diffrent parts belonging to different network" . Please suggest me how to proceed?
Tags (1)
1 REPLY 1
Sorry in my earlier post it was typed as Connect Part but its actually " Merge Network" - Merging network works fine. I made that to be single network. . Is that correct ?
1. My requirement is two diff direction pipes meeet at " T" and takes route towards North. I have two parallel pipes running below road one is Industrial waste water & Rain water .  Pipe slopes are 1:400 for industrial water and gravity flow for Rain water so in pipe properties dialog for Values - Pipe flow direction which is the correct one to give (Start to end or By Slope )
2. After fixing the layput i have to run analysis in SSA to fix the pipe diameter based on the estimated discharge . Is it possible in SSA . I require guidence and suggestion . this is challeging one for me !
Thanks in advance.
Rail Community
