Civil 3D Forum
Pipe Network Structure Label Layers
6 REPLIES 6
accarr03
584 Views, 6 Replies
I have a pipe network created that is shown in multiple drawings.  I created labels for the structures showing Rims and Inverts.  Does anyone know how to put the Rim info on a different layer than the Invert info?  Right now the label has 3 different components...I feel like there has to be a way to put each component on different laters...anyone have thoughts?
thanks!
6 REPLIES 6
ToddRogers-WPM
in reply to: accarr03
3 different label styles on 3 different layers.  Why would you want to do this?
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
troma
Don't think so, sorry.  Each component can be different colours, but not layers.  You may need to make different labels to achieve what you need.  Wish they would allow componant layers though.
Mark Green
Working on Civil 3D in Canada
accarr03
in reply to: ToddRogers-WPM
Ok, thanks.  That's what I was afraid of.  I have a plan that shows the grading of the site and another plan that shows the pipes and structures.  I want to show the Rim elevations on both plans, but the Invert elevations only on the utility/piping plan.
Do you know if I use data shortcuts to bring the pipe network into my Grading plan, can I add structure labels to that plan?  Right now I have a base file with the structures and labels that is XREFed into both plans.
sjg
Yeah I would suggest data referencing your network into each drawing and then label your structures, this way you get more flexibility on how and what you label for each drawing.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
troma
What version are you working in?  I think since 2010 or 2011 you don't need to data shortcut them in if you are just adding labels.  You can just add the label to the structure in the x-ref.
So freeze off the labels that are in the x-ref and add new labels in the Grading Plan showing just the rim elevation.
Mark Green
accarr03
in reply to: troma
I'm in Civil 3D 2012.  You're right, I don't need to data shortcut the structures in.  That's good to know...thanks!
Rail Community
