AutoCAD Civil 3D General
Message 1 of 7 (821 Views)
Pipe Invert Labels in Profiles
821 Views, 6 Replies
10-15-2012 06:07 AM
I am trying to place my pipe invert labels at the actual point of the invert. When using the pipe label style composer, I have selected Anchor Point to be "Bottom Inner Diameter". Why is it that the label style still imports into the center of the pipe? No matter which anchor point I choose the label still inserts to the middle of the pipe. Is there a hidden setting that I am missing?
Thanks.
Bill H.
Civil 3d 2013 under development
Win 7 Pro 64-Bit - Dell T1600
Intel Xeon 3.30Ghz
8Gb RAM
Civil 3D 2013
tcorey
Message 2 of 7 (782 Views)
Re: Pipe Invert Labels in Profiles
10-15-2012 11:04 AM in reply to: dbill2508
I don't think there's a way around it.  When you anchor to inside bottom, the label moves to the invert, but the grip remains at centerline. It sucks because the leader, if used, will point to the centerline.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Joe-Bouza
Message 3 of 7 (763 Views)
10-15-2012 05:22 PM in reply to: dbill2508
The x & y offset and probably an expression should get you where you want to be
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Distinguished Mentor
Message 4 of 7 (731 Views)
10-16-2012 12:29 PM in reply to: dbill2508
Are you trying to label the pipe inverts at the ends of the pipes? Or sonewhere in between?
Message 5 of 7 (713 Views)
10-17-2012 03:06 AM in reply to: dbill2508
Correct, I am trying to label them at the ends of the pipe. We used to use a multileader with a spline leader and invert elevation. But now when you use the style in dragged state the leader only stays in the center of the pipe.
Intel Xeon 3.30Ghz
8Gb RAM
Civil 3D 2013
Message 6 of 7 (704 Views)
10-17-2012 05:46 AM in reply to: dbill2508
If you are trying to label them at the pipe ends, there must be a connecting structure between them. (Perhaps a Null Structure, at the very least.) Why not label the structure? The labels will appear at the pipe ends automatically.
Message 7 of 7 (689 Views)
10-17-2012 07:23 AM in reply to: castled071049
Visual time. Red leader is what I get. Brown Leader is what my company wants.
Attempting to use the offsets and expressions gets the text to move but not the dragged state leader connection, unless I am doing them wrong.
The work around currently being used is to hide the dragged state leader and then add our own after placing the text.
Intel Xeon 3.30Ghz
8Gb RAM
Civil 3D 2013
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
