Ok! I may have gotten bit for doing this but tried utilizing parcels to hatch some widen areas etc. The composition of the parcels is only alignments that I move into a site when I want the area and hatch. Everything was working (and may still be) fine, but I made some adjustments and I have a parcel in one of my areas that is not showing in the prospector. It appears to be the sum of two adjacent areas? Well I decided to change its style to not display and it doesn't and it is nowhere in the prospector? Any thoughts?
Solved by Jeff_M. Go to Solution.
Is it possible that the parcel you see in the plan is not closed? Perhaps after your adjustments the boundary is no longer complete.
That's the part the puzzles? The intended closure show the two parcel with the phantom covering them, but like I say it does not list in the prospector, but if I try to move it to a different site I'm informed it is in the one with the other two and does not show in the list. Weird
Can you find it with QSELECT?
