AutoCAD Civil 3D General
Active Member
Message 1 of 11 (959 Views)
Performance Issues attaching xrefs
959 Views, 10 Replies
07-21-2011 05:15 PM
I'm having a problmen attaching xref's in C3D 2012.  Even statring from a new fresh drawing, when I attach an xref it takes several minutes.  I see the xref appear in the drawing immediately but then C3D hangs for 5 minutes.  I applied the hotfix for xrefs that came out some time ago but that did not fix the problem.  Any suggestions?  Thanks.
Product Support
Message 2 of 11 (913 Views)
Re: Performance Issues attaching xrefs
07-25-2011 11:53 AM in reply to: jkeller
Hi jkeller-
Try applying this performance hotfix and see if that helps: http://usa.autodesk.com/getdoc/id=DL17013122
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
Active Member
Message 3 of 11 (906 Views)
07-25-2011 12:11 PM in reply to: SethHall
I already applied the hotfix you suggest, does not fix my issue.
Product Support
Message 4 of 11 (904 Views)
07-25-2011 12:13 PM in reply to: jkeller
Clearly stated in your original post :smileysad: sorry about that... That hotfix should have resolved this issue.
That being said does this occur with all drawings or just a certain data set?
Are you pulling your data over a network? Try moving the drawings locally and test, see if performance improves.
Does this happen on all machines of just this one?
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Active Member
Message 5 of 11 (893 Views)
07-25-2011 01:12 PM in reply to: SethHall
Thanks for your reply and help.  This problem occurs an all drawings, not just one data set.  I am working on files located on the computer hard-drive (not over a network).  Lastly, I have not tried on a separate machine so I will try that.  Question, could the number of layers or number of sheets (paper space tabs) have any influence on attaching xrefs.  I ask becuase this probkem did not occur until I started working with a template file with a large number of layers and PS tabs.
Jason
New Member
Jbruce1965
Message 6 of 11 (809 Views)
10-13-2011 02:53 PM in reply to: jkeller
We are using C3D 2011 and have noticed many performance issues using Xrefs.  It would be great if Autodesk would implement a button to turn off C3D features when attaching Xrefs.  This could be added to the Xref window beside the "attach" and "overlay" settings as "turn off C3D Features."  What do you think?
Employee
hgohel
Message 7 of 11 (788 Views)
10-14-2011 11:29 AM in reply to: jkeller
What you're describing is something that was fixed by the AutoCAD performance hotfix that is mentioned in this thread.  Could you double-check that the hotfix is, indeed, applied on your system?  Check file versions and dates in your install directory with the version from the hotfix.  Thanks.
Himanshu Gohel
Autodesk, Inc
New Member
Jbruce1965
Message 8 of 11 (778 Views)
10-14-2011 12:35 PM in reply to: jkeller
The hotfix in this link is for C3D 2012.  I am using C3D 2011 E.208.N.0 Version 3.  Is there another hotfix that I should be aware of?
Thank you.
Employee
hgohel
Message 9 of 11 (753 Views)
10-17-2011 06:22 AM in reply to: Jbruce1965
Hi JBruce1965,
The performance problems you are experiencing with C3D 2011 may be something completely separate from what the OP is describing and the hotfix we're discussing for C3D 2012, so it would be best if you start a new thread with details about your situation.  Thanks.
Himanshu Gohel
Autodesk, Inc
jmayo
Message 10 of 11 (744 Views)
10-17-2011 07:35 AM in reply to: jkeller
" Question, could the number of layers or number of sheets (paper space tabs) have any influence on attaching xrefs."
The test is easy. Start a new file with the acad.dwt template unedited and empty. Draw a pline in it and save it.
Start a new file from acad.dwt and place the file above in it as an xref. Does the issue persist?
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
