I can't get a 2014 to Partial Open. I've seen post that say it does work, it doesn't work and it doesn't work if there's some unspecified fault in the template. The command does appear in the Civil 3D 2014 help files. But I've come to realize that doesn't mean anything.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Solved by AllenJessup. Go to Solution.
Doesn't even seem to work in AutoCAD 2014. I created a new drawing with no template in AutoCAD and drew 8 circles on 8 layers. I saved the drawing with Layer and Spatial indices. When I select Partial Open the whole drawing opens with no options to pick any layers.
This is in the vanilla AutoCAD 2014 that comes with IDSP. Not Civil 3D as AutoCAD.
Allen
Allen Jessup
Autodesk has confirmed that Partial Open does NOT work on any drawing that has AEC objects in it. It should work on a drawing that was created in Basic AutoCAD. But once that drawing is saved from Civil 3D it wont work.
A request has been sent to update future Civil 3D help files to make this clear.
Allen
Allen Jessup
A final word. I was still having problems with partial open even when the drawing was created by the basic version of AutoCAD that came with IDSP. Autodesk support traced the problem to the fact that the Civil 3D Object Enabler is installed during the installation of IDSP. The only way to create a drawing in base AutoCAD from IDSP is to turn DEMANDLOAD off. Then create a new drawing.
Allen
Allen Jessup
