Civil 3D Forum
Parcels menu missing
3 REPLIES 3
274 Views, 3 Replies
Hello!
I just installed Civil3D 2007 SP3, but there is no Parcels menu. What could be the reason and where can I obtain the correct Civil.cui file?
3 REPLIES 3
kcobabe
you must have renamed the menu to "Plots." I'm sure if you look under that menu you will find the parcel commands.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
More likely he has installed the International version which uses the
British terminology of Plots for Parcels.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5454412@discussion.autodesk.com...
Ok, thank you very much! I think you are right - it just uses another term for parcels. I just was confused that there is no mention of Plots in the User Guide and no Parcels in my menu...
Rail Community
