Civil 3D Forum
Parcels Renumbering
1 REPLY 1
98 Views, 1 Reply
Parcels Renumbering
Parcels>Renumber Parces has been hit or miss with the project I am working on. The command will number the first few correctly then skip a few and so on. Also, I have noticed that exactly every other time, the starting number chosen is not the same as the starting number the program uses, so I have to run it twice to get the correct starting number. Any others having this problem? Any suggestions? Thanks, Tyler Townes
1 REPLY 1
Tyler: Have you tried to reset the counter Prospector -> Site -> Properties -> Numbering? I seem to have had better success this way. ( Now if someone would just help me on my previous problem. ) Bill "Tyler Townes" wrote in message news:41d08818$1_1@newsprd01... > Parcels>Renumber Parces has been hit or miss with the project I am working > on. The command will number the first few correctly then skip a few and so > on. Also, I have noticed that exactly every other time, the starting number > chosen is not the same as the starting number the program uses, so I have to > run it twice to get the correct starting number. Any others having this > problem? Any suggestions? > > Thanks, > > Tyler Townes > >
Rail Community
