Valued Mentor
awood
Message 1 of 3 (226 Views)
Parcel Spanning label doesn't work
226 Views, 2 Replies
12-19-2013 10:37 AM
In this test drawing, there's one label that doesn't span - on the northern-most lot line.
The 3 other spanning labels work fine, just not that particular one. I've deleted and re-added, flipped, reset, and triple-checked the style.
Deleted and re-added the lot line and checked that the line isn't multiple segments.
Audited, Purged, Copy/paste into a new drawing, inserted into a new blank drawing - still no go.
Can't figure this one out.
Anyone else have any ideas.
AWood
Civil 3D 2014 SP1
Jeff_M
Message 2 of 3 (201 Views)
Re: Parcel Spanning label doesn't work
12-19-2013 07:04 PM in reply to: awood
Each of the intersecting lot lines extends past the lot line you have labeled. One by 0.0041 and the other by 0.0067. In order for spanning labels to work the lot line cannot cross the line being labeled.
Valued Mentor
awood
Message 3 of 3 (181 Views)
12-20-2013 09:06 AM in reply to: Jeff_M
Wow, Thanks Jeff!
Sometimes you miss just the littlest things.
AWood
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
