Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
Did you mean:Ā
Parcel Spanning label doesn't work
2 REPLIES 2
awood
482 Views, 2 Replies
In this test drawing, there's one label that doesn't span - on the northern-most lot line.
The 3 other spanning labels work fine, just not that particular one. I've deleted and re-added, flipped, reset, and triple-checked the style.
Deleted and re-added the lot line and checked that the line isn't multiple segments.
Audited, Purged, Copy/paste into a new drawing, inserted into a new blank drawing - still no go.
Can't figure this one out.
Anyone else have any ideas.
AWood
Civil 3D 2014 SP1
2 REPLIES 2
Jeff_M
in reply to: awood
Each of the intersecting lot lines extends past the lot line you have labeled. One by 0.0041 and the other by 0.0067. In order for spanning labels to work the lot line cannot cross the line being labeled.
awood
in reply to: Jeff_M
Wow, Thanks Jeff!
Sometimes you miss just the littlest things.
AWood
Rail Community
Ā
Ā
