AutoCAD Civil 3D General
Active Contributor
BtimmermanMMS
Message 1 of 4 (160 Views)
Parcel Properties - Analysis
160 Views, 3 Replies
03-12-2014 10:02 AM
Where are the settings for the precision to the mapcheck and inverse analysis to a Parcel?
We have a problem with the bearings showing up with degrees minutes seconds and seconds going out to 100th. Also, the coordinates on the northing/easting show up four places out. Can't for the life of me track down where the precision to these are at. Have found previous threads describing the VB routines that are used for the parcel reports in the toolbox, but haven't seen any control to the parcels themselves. Maybe I'm just overlooking it.
Also, while I'm on this horse...
The analysis shows everything fine, but...have you noticed the segment that is listed first is the last segment you select. At least it is here...
Anyone???
Civil 3D 2013 w/current SP
Windows 7 64bit
HP Elitebook 8760 w/8GB RAM
Jay_B
Message 2 of 4 (152 Views)
Re: Parcel Properties - Analysis
03-12-2014 10:29 AM in reply to: BtimmermanMMS
Have you tried adjusting the various Toolbox precision options found under Parcels here?
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Active Contributor
BtimmermanMMS
Message 3 of 4 (147 Views)
03-12-2014 10:56 AM in reply to: Jay_B
Those settings are the same from day one out of the box. They are set to 3 places and since my settings are (coordinates to 4 and the bearing itself is at 100th on the seconds) I don't think those control my analysis under the parcel properties. I'm leaning towards those controls set more for the reports manager side of things and not the anaylsis tab under the parcel properties itself. Could be wrong...but, my settings don't make sense for what those that you mention are defaulted to. Thanks though...
Active Contributor
BtimmermanMMS
Message 4 of 4 (142 Views)
03-12-2014 11:14 AM in reply to: BtimmermanMMS
Found It!
They are under the Settings Tab and the drawing settings. Right click on drawing name-->drawing settings-->ambient settings tab.
Under the coordinate setting and the direction setting they are set to 4 and 6 as a default. So, i've changed my coords to 2 and my direction to 4.
Ran the parcel properties analysis and Whalla!
Next it would be nice to write that portion out to a text file or something, but i guess that is why "they" give us the toolbox reports side of parcels and whatnot. Anyway...another problem solved. Onto the next...
Thanks anyway folks...
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
